lets talk turbine wheel size
Old Feb 9, 2013 | 09:33 PM
  #21
lglowe's Avatar
Borg Warner s400 t4 with a 88 comp and 92 turbine is the biggest I know of. That'll make a **** load of power.
Old Feb 9, 2013 | 09:37 PM
  #22
Yea bw rates their turbines at the inducer and iirc the 92mm turbine has about a 84-85mm exducer which would be sick! That turbo would move some air!
Old Feb 10, 2013 | 09:49 AM
  #23
TURBHOE's Avatar
Dad gum, those QSV's are the price of a small turbo.
Old Feb 10, 2013 | 10:19 AM
  #24
Yea screw those things lol
Old Feb 10, 2013 | 10:20 AM
  #25
kbracing96's Avatar
Somebody needs to build these for Gas turbos setup!
Blaylock Turbochargers | Switchblade Turbo | Motorcycle Turbos | Power Stroke Turbos | Cummins Turbos | Duramax Turbos | Powerstroke Turbos
Old Feb 10, 2013 | 02:51 PM
  #26
TURBHOE's Avatar
But if a person has the cash to do so. A compound set up with a QSV on both turbos would be in real. Low low rpm spool and great top end with everything in between. Lol. Or even a twin setup with on on each turbo. Then you could size your turbines a little bigger and be able to spool faster with top end like a big single.
Old Feb 10, 2013 | 02:54 PM
  #27
TURBHOE's Avatar
Wow that's pretty awesome.
Old Feb 10, 2013 | 03:08 PM
  #28
Atomic's Avatar
I have a gauge for that
So do it already!
Old Feb 10, 2013 | 03:33 PM
  #29
smokeshow's Avatar
Mod with training wheels
Yet still cheaper than the additional turbo, wastegate, hot pipes/fabrication, oil lines, etc. that you'd need in order to pull off a compound setup... Might as well build a sequential boost setup if you plan on having better low end with a big turbo
Old Feb 10, 2013 | 03:59 PM
  #30
sequential setup would be the coolest route!! Kyle, that is a pretty slick device. Kind of like a variable vane nozzle but a different way to do it.
