Lets build a 408ci + Turbo
Old Mar 18, 2016 | 09:18 PM
regency's Avatar
Default Lets build a 408ci + Turbo
So as the title states I want to pick your brains...!!
Lets make paper build that in perfect situations will produce 900-1000 rwhp
Starting with a 408 ci short block, lets put heads, intake, and fuel. Then we will need to size the turbo and all piping.
I have read some about the turbos and setting them up but know next to nothing about doing it because ive never done anything with them.
I know its more than enough motor to do it but my thinking was to not have to boost as hard and make the engine last longer.
Old Mar 18, 2016 | 09:22 PM
GMCtrk's Avatar
S480 with race cover
Stock heads and intake
Old Mar 18, 2016 | 09:24 PM
regency's Avatar
What psi?
Old Mar 18, 2016 | 09:29 PM
GMCtrk's Avatar
I see 20-22psi down the track which is around 950
Old Mar 18, 2016 | 10:26 PM
Gadgetized's Avatar
I made 955RWHP at 22 PSI. Stock cover cast wheel. I would also suggest the race cover. I will more than likely be switching to an 84mm billet wheel and V2 race cover. That should be enough to put me well over 1000 if i want to push it.
Old Mar 19, 2016 | 01:19 AM
Blown06's Avatar
8 Second Truck Club
Originally Posted by GMCtrk
370
I think you missed the 408 part
Old Mar 19, 2016 | 08:46 AM
George C....'s Avatar
Formerly ScreamingL
For only 900 rwhp goal a stock strong rod with a JFR cam will do it with studs and gaskets
Old Mar 19, 2016 | 09:20 AM
Lil brother PI's Avatar
https://www.performancetrucks.net/fo...inside-542740/
408 stock heads prbly get to the 1k mark if it they push it
Old Mar 19, 2016 | 09:30 AM
Formerly ScreamingL
Parish in 2006 did over 1000 on a 408 with stock heads on pump gas........
Old Mar 19, 2016 | 09:44 AM
That was 10 years ago and way ahead of the game back then we have come a long ways
