Kbracing turbos?
Old Oct 31, 2013 | 08:22 AM
RockChevy's Avatar
Originally Posted by kbracing96
Almost, kbracing96
Let me know what I can do for you.
hey Kyle I live in Autsin just a couple hours drive from woodlands im working on piecing together a turbo build for a 4.8 I will PM you.
Old Oct 31, 2013 | 09:10 AM
kbracing96's Avatar
Sounds good!
Old Oct 31, 2013 | 09:35 AM
Originally Posted by walledition
i understand but seems like being at 7000ft above sea level, i dont need near as much fuel then you guys with the same combo (of course i dont make as much power) someone correct me if im wrong but i have alot less air here so i need alot less fuel
You will need 38 lbs at a min and 255 pump...
Old Oct 31, 2013 | 10:00 AM
CDOlguin's Avatar
Registered User
Would the same size apply for a 4.8?
Old Oct 31, 2013 | 11:56 AM
walledition's Avatar
i agree on higher boost i´ll need bigger injectors and pump but dont you think i´ll be fine running 5psi with stock ones? i attached an hp tuner log with the setup i have now (6.0 bolt ons and cam) im here to learn so correct me if im wrong, injector duties isnt maxed out at all now is it?
File Type: hpl
Old Nov 1, 2013 | 10:26 AM
kbracing96's Avatar
If you insist on running stock injectors with a 6L on boost, then you better limit you boost to about 4lbs and no more then 4000rpm... But why risk that much money and work over a set of $250 injectors??? Personally, I think it's foolish...
I don't have HPT on this comp, but I'll look at you log when I get to the shop.
Old Nov 1, 2013 | 12:52 PM
kbracing96's Avatar
Your injectors are currently at 81% dc and your shifting ant 66-6700 rpm! You put any boost to that at all any your gonna max them injectors out and your motors gonna say I hate you and good buy!! lol
5lbs of boost is about 1/3 more air, which means you gonna need about 40%+ more fuel since FI need to be richer then NA. That's gonna put you well over 100% DC on those injectors.
Old Nov 1, 2013 | 09:11 PM
don't get me wrong man! i understand and of course i´ll change injectors its just that couple of times i sow people with similar combos as mine maxing out the injectors and i sow mine where at 81% i tough i was getting away with 5% but i see i don't, thank you for explaining
kha4079
Oct 29, 2018 04:38 PM
lxcoupe
Sep 6, 2017 08:24 AM
chvy=power
Sep 8, 2015 11:06 AM
slowswb
Sep 5, 2015 02:27 PM
06murder
Sep 4, 2015 03:54 PM
