KB Racing Kit recieved
Old May 24, 2011 | 07:54 AM
JFOLM's Avatar
How does it run on a base tune?
Old May 24, 2011 | 01:01 PM
black6spdz's Avatar
it does not idle well, but once it is over 2k it is ok. It may be because i used a bosch injectors and i think TJ normally uses siemens. The tune has 10* or less advance and is rich. I have made 10psi with the tune just to make sure everything was good and it was not going to be blowing couplers and having problems on the dyno. I also wanted to make sure i had the correct spring in the wastegate as i am not going to run a boost controller for now.
Old May 24, 2011 | 01:39 PM
smokeshow's Avatar
Mod with training wheels
Looking forward to seeing some results!
Old May 24, 2011 | 03:12 PM
Sierra1320's Avatar
Sounds like it should reeally run after you get it tuned. What did you use for the exhaust?
Old May 24, 2011 | 03:19 PM
TIM Z's Avatar
11 sec. Truck Mod
Originally Posted by black6spdz
The kit is finally on and it fit very well. The truck is running on a base tune currently and going to baker engineering for a dyno tune tomorrow.
Baddass! Congrats on the kit. TJ will have that thing runnin like a champ, he's an excellent tuner and one hell of a good guy!!!
Old May 24, 2011 | 08:07 PM
slowlsx's Avatar
As far as I know your lieng! We need pics!! You might be the first ss with kb kit? That's awesome ! What is the s473 rated at? Never herd of that one
Old May 24, 2011 | 09:50 PM
KDavis04ss's Avatar
I need to see some pics also. But not the first SS with a KB. Theres a guy in Alaska running a 76mm running 12.20s
Old May 25, 2011 | 07:14 AM
black6spdz's Avatar
Sorry I meant S472 with the 83mm turbine wheel. It is rated at 850. He is very good, he has done some f body cars for me. The exhaust is all 4" mandrel bent that we built with a six inch round dynomax that is about 20" long, it ends at the stock location but is tucked so you do not see the exit.
Old May 25, 2011 | 08:28 AM
OnyxSilveradoSS's Avatar
TJ is gonna have fun with that. please keep us posted, I have high hopes for that turbo and the SSS
Old May 25, 2011 | 11:39 AM
BadAssChevy327's Avatar
subing! sounds like a very fun truck to drive on the street once tuned. can you imagine peopls face when you build some boost at light and leave spinning all 4
