Kb kit check list.
Hey guys have a few questions hope you can help me out. I have a kb racing hot pipe kit coming and was wondering if there was a thread (I've tried looking just didn't know what exactly to search for) or you can tell me like a check list that has to be done for the install, I know the main things. Thank a bunch!
Ok ill that's a good start what I have:
Kb hot side kit, on3 76mm turbo, x02 60mm wastegate, tial bov, cxracing intercooler, zr1 takeout injectors.
I had an sta kit on a truck awhile back, so just trying to refresh my mind for the build, I guess my main concerns are everything on top of the intake. I believe the check valve? I'm just drawing a blank on that part.
Cold piping obviously, oil lines as mentioned (feed and return), probably should look into wrapping the hot pipes, boost controller, boost and wideband gauges, lines to plumb the BOV, boost gauge, and wastegate, you will need to come up with a PCV system, injectors, tuning of course, 2/3bar MAP sensor if you go that route with your tune.
Steve-O-08
Apr 19, 2018 09:32 AM
Stainless Works
Apr 10, 2016 04:34 PM
