Just another 400inch WCCH Engine with a T6 flange Rear Mount !!
Old Oct 3, 2008 | 05:01 PM
  #21
Casey2323's Avatar
Originally Posted by explorer5.0
....your wastegate is on backwards....
it bolts on the same on either side and yes it was upside down when i took the pic.think it was flipped looking at any type of clearance problems i might have and different angles.. I never took a pic of the truck turbo system completed.. but thanks for the info ....
Old Oct 3, 2008 | 05:05 PM
  #22
Mort's Avatar
Casey, Your truck looks great. Glad to hear that you are burning them up (the tires that is not the rest of your stuff....LOL).
Good luck and waiting to hear more.
Get that waste gate turned around.
Old Oct 3, 2008 | 05:33 PM
  #23
XLR8NSS's Avatar
Adkoonerstrator
That is a pretty unique setup! Very cool and well done!
Old Oct 3, 2008 | 06:55 PM
  #24
kbracing96's Avatar
Not sure if your following what we're saying, or if you saying you fixed it, but in that pic your exhaust pipe is bolted to the outlet of the WG, it should be bolted the the other flange which is the inlet of the WG,
Old Oct 3, 2008 | 10:59 PM
  #25
Casey2323's Avatar
Wastegates are under contol ... Thanks for the reply... I will take a better look @ my pics before i post them...
Old Oct 3, 2008 | 11:26 PM
  #26
vanillagorilla's Avatar
I was going to say, if you're driving around and boost is being controlled, then it must be on right. Otherwise, that turbo would peg your boost gauge pretty damned quick.
Old Oct 4, 2008 | 12:11 AM
  #27
TchargedLS1TA's Avatar
Yo Casey, what happened to the front mount turbo?
Old Oct 4, 2008 | 12:23 AM
  #28
My buddy accidently did that with his homemade front mount kit. The stock 6L in his c3 didn't care for that much boost either, every rod is twisted in the motor. He did say it was a wild ride for the few seconds it lasted though
Your truck and turbo set up look sweet casey2323
Old Oct 4, 2008 | 09:29 AM
  #29
Casey2323's Avatar
Umm... I didnt even know u were still alive.... if your talking about my front mount I had before i sold it... I went to a large frame and nothing was even close to fitting... to small a cross over,downpipe... so i sold all of it and went bigger I only have small bugs now and this turbo spools as good or better then my front mount with a P trim and .96 hotside and my tune is junk.. I get my small bugs worked out and better tune and lag will be little of nothing...
Old Oct 6, 2008 | 12:11 AM
  #30
Wilde Racing's Avatar
How do I change this text
Looks sweet, I'm glad to see a REAL mean looking rear mount. Congrats!! The months of hard work will start paying off now......
