J tube torque specs?
Turbos | Superchargers | Intercoolers | H2O/Meth Injection
May 11, 2008 | 09:06 PM
BLASTER
Feb 2003
bridgwater, nj
Just installed my 90 mm j tube and searched for the specs but can't find them. Does anyone know the specs? Thanks
BLASTER
Visit BLASTER's homepage!
Find More Posts by BLASTER
May 11, 2008 | 09:22 PM
Stoichiometric
Nov 2005
Way out there
I torqued mine to 20ft lbs. If you use loctite aluminum flange sealant you can almost get by with the bolts hand tight, it will make a perfect seal.
Stoichiometric
Find More Posts by Stoichiometric
May 11, 2008 | 09:26 PM
BlownChevy
blownerator
Mar 1986
Chatsworth, CA
Quote:
Originally Posted by
Stoichiometric
That will be fine
BlownChevy
Find More Posts by BlownChevy
May 13, 2008 | 06:40 PM
BLASTER
Feb 2003
bridgwater, nj
I used loctite 510 to seal the flange. thanks for the specs I'll go 20ft lbs
BLASTER
May 13, 2008 | 08:07 PM
terravast4
Jul 2007
Austin, TX
any helpful hints on removing the j-tube? I am getting ready to do mine. Thanks.
terravast4
Visit terravast4's homepage!
Find More Posts by terravast4
May 14, 2008 | 06:28 PM
BLASTER
Feb 2003
bridgwater, nj
i took the blower off. figured it was the easiest way
BLASTER
May 14, 2008 | 06:29 PM
terravast4
Jul 2007
Austin, TX
I didn't want to do that but I guess you are right.
terravast4
2010 ly6 6.0
chvy=power
11:06 AM
Cammed 4.8
USMCvet0311
09:43 PM
Custom cam spec opinion
2500ZL1
12:23 AM
Dyno Results seem right? LQ4 / S475
NuckenFuts
Jul 9, 2015
08:45 AM
Tags
petrochemical
specs
torque
troque
tube
Back to Subforum
View Next Unread
Rebuild: Turbo & Fast??????anybody
11:40 AM
