Intercooler or Meth Help
Old Jan 4, 2008 | 12:06 PM
Vortec HD's Avatar
Default Intercooler or Meth Help
I am looking to get a little more out of my Powerdyne. I am not sure which route to take. What are the benfits of each in relation to cost, fabrication, performace gains?
I currently am at 8psi with 44lb injectors, and dont want to kill the blower bearings, so looking at the timing and tune now. Any help, guidance, or experance would be great.
Remove this ad. Become a supporting member.
Old Jan 4, 2008 | 12:26 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Welcome to the forum, I moved your post to the forced induction section, hopefully you will get some good opinions here.
Old Jan 4, 2008 | 12:31 PM
Best thing would be to be to intercool it, once this is done then tunning will also help out.
Old Jan 4, 2008 | 02:35 PM
thunder550's Avatar
High on diesel fumes
I'd also vote for intercooling it first. Meth will help if you're close to maxing out your injectors or if you're getting knock, but it would be best to cool the air charge before all of that.
Old Jan 4, 2008 | 03:04 PM
dewmanshu's Avatar
Moderately Differentiated
intercool FTW
Old Jan 4, 2008 | 11:11 PM
RedHot04's Avatar
Originally Posted by Vortec HD
I am looking to get a little more out of my Powerdyne. I am not sure which route to take. What are the benefits of each in relation to cost, fabrication, performance gains?
I currently am at 8psi with 44lb injectors, and don't want to kill the blower bearings, so looking at the timing and tune now. Any help, guidance, or experience would be great.
Put the IC on you will only lose about 1-2 psi. and maybe 50 shot of nitrous IMO. HSW has a great deal on the kit. Your gonna burn up the bearings and shred the belt it's just a matter of time if you have the BD-11A unit and decide to run anything over 9 psi. or run it hard at the track. But it's not all bad news you can order the ceramic bearings and Kevlar belt to beef up a bit. If you're looking to keep up with the crowd better upgrade the head unit and take care of the tranny first. It only took me a couple months after I put mine in to destroy both!
Old Jan 5, 2008 | 02:01 AM
WJ MARK's Avatar
intercooler!
Old Jan 5, 2008 | 08:42 AM
TrickTurbo's Avatar
Truck Sponsor
With your limits on blower/psi I would recommend water/meth kit. The intercooler you will loose boost pressure and the only way to make it up is to turn the blower harder. Now all w/m kits are the same, some use varable pump speeds and orifices to controll the flow. I like the FJO units, tuneability and smooth control and a very fine mist which aids in cooling greatly. If you flood the water/meth to soon, too much, or too big of dropplets you loose power.
What IAT's are you running now?
Old Jan 5, 2008 | 09:00 AM
dewmanshu's Avatar
I know we have spoke about this a hundred times, but on a non-intercooler setup, what is the actual temp benefit of a particualr sized meth jet? Or water? Short of putting the meth/water inj ON the IAT sensor. Trick you bring up a good point of pressure loss, but I can't imagine at that power level any meth/water kit making a substantial difference. SUBSTANTIAL is my arguement here, substantial enough to say no to an intercooler.
Old Jan 5, 2008 | 09:28 AM
MikeGyver's Avatar
In all of the time that I have had an intercooler, it has yet to go empty, leak, or break down and ruin my engine.
