Inlet Forward/Rear Drive TVS2300 LS2/427 L92 Heads and Cam
Old 03-18-2009, 11:55 PM
  #31
WOW.....Tvs 2300 here I come.
Old 03-20-2009, 10:55 PM
  #32
zippy's Avatar
Should be fun. I'm interested in checking it out in person. Very nice looking install. I'm sure it's a huge improvement over that MP122.
Old 03-21-2009, 09:41 AM
  #33
FormerVendor
leftcoast32's Avatar
The biggest thing now is finding enough fuel to support the boost you want. I am going to design a new fuel cell and pump system that is boost referenced for it so we can crank the boost all the way up.
Old 03-21-2009, 04:59 PM
  #34
wkdivr's Avatar
I think the hardest part of that is going to be how to get a return line into the factory bucket, with the big evap piece on there. On mine, there's just no room for everything without eliminating something to make room. I'm thinking it looks something like mine if it's a returnless system. I think doing something like a Bosch 044 intank, with the return line plumbed to feed back into the bucket to keep it in fuel when the level is low.
Old 03-21-2009, 07:42 PM
  #35
FormerVendor
The next fuel system we build will be a complete new one with an external pump and boost referenced regulator.
We did all the fuel system modification to his 2 weeks ago and it needs more to raise the boost levels. Keep in mind that it is a 427 with 14 psi and takes alot of fuel.
Old 03-21-2009, 09:54 PM
  #36
Banned
MagnaCharger Rep's Avatar
Nice work Joe!
Old 03-23-2009, 07:27 PM
  #37
FormerVendor
LEADING EDGE PERFORMANCE's Avatar
Joe and Hank congrats on the build. Very nice. See you this weekend at the shop!
Garth
Old 03-27-2009, 07:00 PM
  #38
High on diesel fumes
thunder550's Avatar
Originally Posted by leftcoast32
The Rear Cog has a very distinctive sound like the drive on an old 6-71 Supercharger.
How loud is it inside when you're just cruising around?
Old 04-05-2009, 09:11 PM
  #39
Whippled 496's Avatar
Sorry if this is a little off topic, but can you explain to me on a setup like this.....what is the benifit of the jack shaft? Is it so you can run a larger pulley out front and a smaller pulley in the rear to spin the blower faster?
Old 04-05-2009, 09:22 PM
  #40
Adkoonerstrator
XLR8NSS's Avatar
Pretty much Jim. With the front drive you are kinda limited to how fast you can spin the blower by the crank pulley size and blower pulley size. On the rear drive you have those to adjust too so you can spin things faster.
Quick Reply: Inlet Forward/Rear Drive TVS2300 LS2/427 L92 Heads and Cam
