Injectors
#42
No, its actually a little lean at startup which I need to look into...
Pulsewidth sitting at idle at 750rpm is approximately 2.5ms and these have a min pulsewidth of 0.122ms
#44
Yes, its only lean on hot restarts, I just havent spent enough time tuing that area. Looking at other logs its around 2.2-2.3 at idle most of the time. Im using 58psi base pressure.
#45
Sooooo put the 84# injectors in last night and tuned it.. went to jglowe's to check out his new turbo, and did some tuning.. saw 144% IDC on these.. so i called Jon at FIC and told him whats up..
Im getting the big boys on the way..
#47
Something has got to be wrong if your at 144% with 84#ers
#48
95s are on the way..
running 84s right now.
thats quite a few hp on ~15psi.. i gotta look back at my log. it might have been 16psi.
it started goin a lil lean so i let out.
its amazing at the difference from a small on3 turbo at 12psi and a S475 on 12psi.. it takes a bunch more fuel.
#49
#50
Oh.... Well i am staying tuned because i will probably gonna buy whatever injectors you end up with
Mr. Ginny Pig
