I'm modding a trick cast manifold for 50mm! Pics inside.
Old May 13, 2014 | 09:58 PM
  #31
cpolaris502's Avatar
I drilled and tapped the pan when I built the engine last year.
Oil lines are probably 15* off vertical. In the working range. With how large the drain hole is,
Old May 14, 2014 | 12:24 AM
  #32
AkSSS's Avatar
Originally Posted by timmay208
i wont be doing it on the vehicle, ill pull the pan and drill and weld the fitting. Its worth the extra time for me not to worry about shavings in the oil pan
I spent almost 2 hours drilling my return on the passenger side of the pan and never had a problem. Used lots of grease and cleaned the bit so many times I can't remember. Ran the truck for 3 years. Pulled my pan a couple months again, this was what I found. Was going to just do a cam swap. That turned into a motor.
I'm modding a trick cast manifold for 50mm! Pics inside.-image-2477826611.jpg
Those shaving were too big to be anything except from drilling the turbo oil return. The rear cam bearings were toast but that could have been the shavings.
Old May 14, 2014 | 06:44 AM
  #33
TURBHOE's Avatar
When I drilled and tapped the 5.3 years ago I used a shop vac. It was running the whole time we were drilling and tapping. Last year when I lost the motor do to the cam gear breaking, there was nothing in the pan beside piston bits.
Old May 14, 2014 | 11:06 AM
  #34
timmay208's Avatar
I wont chance it, takes maybe 45 min to get the oil pan out, plus i like to weld my fittings
Old May 18, 2014 | 09:09 PM
  #35
I just about finished it up this week. Just need to plasma cut a hole in the down pipe to run the wastegate into and final weld everything. Looks like it's going to work out perfect.
I'll probably just have to cut out the plastic inner fender a little but for some clearance.
Old May 18, 2014 | 11:27 PM
  #36
xx_ED_xx's Avatar
4 inch dp?
Old May 19, 2014 | 05:00 AM
  #37
It is.
Old May 19, 2014 | 08:59 AM
  #38
boostedsl2's Avatar
Nice work! Looks good.
Old May 19, 2014 | 09:19 AM
  #39
Choda's Avatar
Wow. That turned out really really nice!!!
Old May 19, 2014 | 08:55 PM
  #40
Cool, thanks a lot. Wasn't trying super hard, lol.
