Ice in the reservoir
So I am going to install my oversized reservoir this coming weekend and see what effects having about another gallon and a half will have on my IATs. Also want to throw some ice in there too and see what happens, but I have never done that before. Whats the best method, just dump some ice in the reservoir and forget about it? Do i need to worry about ice getting in the line and blocking flow? I know it would melt and not block flow long, just not sure what the best way of adding ice would be.
I just put ice in the reservoir after draining some heated water from the system via a flush valve that I added to a lower coolant line.Then I allow the chilled water to circulate a min. or two before staging.
I did the same thing. I used the larger Vortech reservoir and drained quite a bit of the coolant out before a run. I'd top with ice, then toggle off the intercooler pump so it didn't waste the icy water until I was in the staging lanes. It worked quite well. Just don't forget to refill with some antifreeze afterwards.
Isn't there some pain-in-the-*** filling procedure for your (Whippled 496) system? I mean, if you let some water out, won't you have to go through it all again to get the air out?
On another note, I gave up on my refrigerated water cooler design. I am too lazy to figure out how to shut the compressor off at a certain (high) rpm like the PCM does, when operating in water cooler mode.
Why couldn't you take a cylendar and coil some copper tube or aluminum tube and make several coils in side the cylendar so it can help cool the fluid but make it big enough you can put some dry ice or any thing of that sort to help rapidly cool the fluid
