i just dont get it
#21
TOTM: January 2007
I think you need yto figure out why your intake temps are so high. Dont buy a cam, injectors, or anything else until you can figure that out. I am not sure why you are running so much meth, i dont think there is any need for 2 nozzles. I have a 6.0 with a 2.9 pulley, and am using 1 nozzle and my controller is set at 4 on a scale 1-10.
With a 3.1 pulley, you should be able to run at least 20 degrees of timing all day. Going from 12 degrees to 20 is going to be worth a ton of power. I have no clue how your intake temps can shoot to 190 with meth. I would trouble shoot your intercooler problem before anything. I dont think my intake temps climb pass 160 with the meth.
#22
Is your resevervior full? Is your pump working? Look there first, because those are common causes of abnormally high IAT's.
Also it could be that since you're spraying sooo much meth through the Radix that the coating has come off and clogged the HX. I've never heard of it happening, but stranger things have happened.
When you're on Nelson's dyno, do the #'s correspond to your 96mph trap speed. If not, then it might be a drivetrain issue like a loose converter.
#23
TOTM: January 2007
#26
well i have the 3.1pulley on an my iats were at in town were 10*'s over ambient. i mean i've check the i/cpump and resevior. but how can i trouble shoot it to find out. i feel dumb asking, but yet learn from you all with time. and the sad thing is i dont even have a cam for my iats to sky rocket so fast.
#28
well i've done that and the pump is working and the i/c resevior is full. so what else could it be. i mean i did have the 2.75 which was generating alot of heat, thats why i took it off and put the 3.1 on instead. im not running meth just whatever the washerfluid had so i can cool my iats. so i disconnected 2 nozzles stayed with one and dump the washerfluid and just added water.
#29
Destroyer of Transmissions
What % of meth is the fluid? I dont know that you should add water to it. IF its already a low % of meth then you're diluting it and probably are closer to straight water. Which isn't bad, but not as good. The 2.75 on a 5.3 was generating a ton of heat I'm sure. How quick do your IATs recover after a run?
#30
im thinking about 20% of meth in the washerfluid. i cant remember but i'll find out. but a 13.57@96mph @65*'s and 100%humidy with a 60ft@1.89 does that sound right, i tried both pulleys and wasnt a noticable difference on them.
