Hummer with sts turbo fuel problem
What spring(3.6psi, 5.8, etc.) do you have in your wastegate? If you have the 5.8 psi spring and you have the boost reference coming from the turbo to the wastgate then you could be getting 4 lbs because of the losses from the i/c. But you can get the reference from the brake booster instead and you will see a full 5.8 psi.
lxcoupe
Jul 21, 2015 02:12 AM
Mossyoakglock
Jul 17, 2015 08:30 AM
