how rich is too rich?
i see alot of people use lambda but for me just seems common sense if my pcm commands a hi res commanded afr then why not read Afr when recording.
my hp tuners pid takes the two and gives me a % err
Log the equivalence ratio pid, its the inverse of lambda and is the value in the pe and be tables as well as the open loop table. The afr pid is computed by equivalne ratio and the stoich afr number in the tune. Your wideband analog output should also have a lambda transfer function.
