How much more should I expect?
Old Feb 3, 2009 | 07:37 PM
terravast4's Avatar
Default How much more should I expect?
I am getting ready to put the truck in the shop. i am adding PRC stage 2.5 5.3 heads, gt2-3 cam, j-tube and 90mm tb, 60 lb injectors and lingenfelter 100 mm maf also an extra magnuson heat exchanger. The dyno #'s in my sig do not include the long tubes or the 3" exhaust, i was running shorties and a 3" catback so count those in the mix. do you think 500 rwhp and maybe 550 rwtq is reasonable to expect??
Old Feb 3, 2009 | 09:00 PM
03tahoe22's Avatar
Everything in my sig and I got ~410rwhp and ~490rwtq at ~11psi on 22's ... have read if I had dyno on 17's I would have gained 30rwhp and 30rwtq. Should be there easy but might need meth to cool the boost since my iat were climbing with a 3.0 pulley.
Old Feb 5, 2009 | 02:13 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
I think you should get that easily on a dynojet. Who are you getting to do the work? Are you coming to the ls1truck track day at SAR later this month?
Old Feb 5, 2009 | 02:42 PM
rockerjoe2008's Avatar
I really have no idea but I think you should be close. Good luck, hope you get there!
Old Feb 5, 2009 | 07:50 PM
terravast4's Avatar
I use a shop here called auto-tek for all the stuff out of my league. Yes, I am gonna go to track day at SAR but probably as a spectator. I am not gonna get the work done for about another month. I could make a few passes on street tires but not sure I really want to.
FlowmasterMufflers
Nov 24, 2015 01:00 PM
bearden86
26
Nov 15, 2015 03:58 PM
zblee
Sep 17, 2015 07:58 AM
FormulaZR
Sep 14, 2015 05:23 PM
FlowmasterMufflers
Sep 11, 2015 03:32 PM
