how much boost will I be making
Old Dec 10, 2013 | 05:57 PM
ou812sm's Avatar
Default how much boost will I be making
Ok here is what I have 2.3 whipple on of a 416 stroker the pulley on the whipple will be 2.75
Crankshaft will have a 10% overdrive pulley
Nick William 105 tb
Arh 1 7/8
Cam specs are 224/236 .644/ .644 117 lsa
I'm just looking for a rough estimate
I'm estimating about 14-16 #of boost what do you guys think also how will the 10% over drive affect the other pulley driven items
Old Dec 11, 2013 | 12:01 PM
ou812sm's Avatar
Anybody have an idea
Old Dec 11, 2013 | 12:42 PM
Atomic's Avatar
I have a gauge for that
Well the stock truck pulley is like 7.55" so 10% OD is 8.3"
2.3L is 140ci, and blower pulley is 2.75"
So blower CFM at 6000rpm is (140/12^3)*6000*(8.3/2.75)=1468
Engine CFM at 6000rpm is around 650cfm
1468/650=2.25
2.25*14.7-14.7=18.5psi of boost
Very rough estimate...
OD pulley is fine....everything just spins 10% faster. The problem with pulleys is when you use UD pulleys.
Old Dec 11, 2013 | 12:58 PM
Vortec350ss's Avatar
That sounds like a lot of boost... and a tiny *** pulley if the stock pulley is a 7.55"
If I were a betting man I would say you're gonna have belt slip if it truly is that much smaller than stock.
Old Dec 11, 2013 | 02:30 PM
ou812sm's Avatar
Ok 18.5# roughly is that on the 416 stroker or is that on the stock 6.2
Old Dec 11, 2013 | 02:31 PM
Atomic's Avatar
416ci
Old Dec 11, 2013 | 03:14 PM
ou812sm's Avatar
Ok one more for you 18.5 being a rough estimate is that on the high side or low side and the 18.5 would be at peak
Old Dec 11, 2013 | 03:19 PM
Atomic's Avatar
It is on the high side. You will get some belt slip and the blower volumetric effeciency is not 100%. I would bet you will see a peak of 17psi and it falling off up top to around 15 due to belt slip. I hope you are planning on at least an 8rip belt setup.
Old Dec 11, 2013 | 03:24 PM
ou812sm's Avatar
Well the crankshaft will be 8 rib the rest will be 6 rib thank you atomic you are a big help
Old Dec 11, 2013 | 03:26 PM
Atomic's Avatar
No problem, but from my own experience that blower pulley is way too small for only a 6rib belt. You will be constantly fighting slipping/stretching belts until you upgrade.
