How much boost is possible
Old Apr 1, 2009 | 04:34 PM
QWK-293's Avatar
Banned
Originally Posted by viciousknid
Search works fine in Firefox. I don't know why they won't get the stupid bugs fixed in IE.
As stated above. there are a LOT of factors that determine your boost. Do you have a 327 Gen 1 engine or a 5.3 (325) Gen III? Do you want your 4l60e to blow up as soon as you get in the throttle the first time?
Street driven? Reliable?
Stock engine? Cam size? Truck weight? Gears? Heads? Turbo or Super?
It's much easier to tell us What you want to do and what your willing to install to get there.
With a question of how much is Possible. Well, stock 7 +- depending on how heavy the truck is, Build it up and you can see into the mid 20's or more.
I have no idea what you mean. The truck is a 99. I was told it has the vortec motor in it. I thought it had a 700r4 in it.
Old Apr 1, 2009 | 04:51 PM
BlownChevy's Avatar
blownerator
25 Year Member
99 truck or suv?
Old Apr 1, 2009 | 04:56 PM
Whippled 496's Avatar
Originally Posted by DozerDan
...CRANK IT UP PHUCKER!!!!!
lmao....
Old Apr 1, 2009 | 05:08 PM
thunder550's Avatar
High on diesel fumes
I think you misunderstood. The 99's had Vortech, not Vortec. Go look closer at your engine. There is a factory installed supercharger hiding between the fan shroud and fuse box. It’s small, only designed for about 4 psi, but it’s there.
Old Apr 1, 2009 | 05:22 PM
Wilde Racing's Avatar
How do I change this text
Lmfao at this thread...... Right before it blows up, stop turning it up...
Just max out your boost controler, should put you in the 16 pound range, throw about 10.5 :1 fuel at it, with 20 deg. Of timing.... Should put you in the 698-700 range....
Old Apr 1, 2009 | 05:27 PM
MikeGyver's Avatar
Since you can't search, here is a link to a thread that explains it all:
https://www.performancetrucks.net/forums/showthread.php?p=4170523#post4170523
Old Apr 1, 2009 | 06:36 PM
dirt track racer 81's Avatar
run it till it blows and back off a little
Old Apr 1, 2009 | 07:13 PM
Parke10's Avatar
well said. that seems to be the best way to go at it.
Old Apr 1, 2009 | 07:14 PM
SincalT/A's Avatar
poor guy jus wants to go fast ):
Old Apr 1, 2009 | 07:31 PM
QWK-293's Avatar
Banned
Originally Posted by BlownChevy
99 truck or suv?
99 sierra, everytime I try to use the search It comes up wierd. I searched turbo and it came up shamwow
