how to get more HP from Turbo 5.3
also put a boost gauge before and after that intercooler. i have seen some have drastically different specs in and out. you might be shwoing 19 psi in front, but maybe only 14 psi our back. Also, how are you tuning? all seat of pants? might need to get ont he dyno to actually see where you are or are not making power.
at 19 psi, if its a true 19psi, you should be making more power
also put a boost gauge before and after that intercooler. i have seen some have drastically different specs in and out. you might be showing 19 psi in front, but maybe only 14 psi our back. Also, how are you tuning? all seat of pants? might need to get on the dyno to actually see where you are or are not making power.
I tune 90% at the track. Been on the dyno but dyno had some issues one of the times I was on it. Showed about 600 rwhp the other time. Track has been a much better and more repeatable way to tune for me.
You have a restriction somewhere. That’s pretty low numbers for what your pushing. The engine combo should be fine, I suspect your intercooler or turbine is choking it. Or both. You can measure pre intercooler pressure and also measure exhaust back pressure pre and post turbo and that will tell ya. It’s easy to rig up a temporary gauge to measure them. I actually have mine setup to measure back pressure easy. It’s valuable info about what’s going on.
I can tell you from my recent experience with the ebay 31x12x3 intercoolers that they are a huge restriction. On my 86 c30 6.0 with a torqstorm blower I was making 7 psi at 6200 rpm. I switched to a mishimoto universal r line 31x12x4 intercooler and it now makes 10.5 psi at 6200 rpm. Iat is also down about 15* as well.
68Formula (11-09-2020)
Hahahahaha. That reminds me of the time I saw a pontoon boat with a big V8 in the river. It would stand almost straight up when he nailed the throttle. It cracked me up to see that, just as would seeing an '84 Mercury Colony Park go fast.
Do you have it made up to look like the Family Vacation station wagon? Hahahaha
RedXray (11-10-2020)
The following 3 users liked this post by drhill:
Now I just need to mock up pressure sensors for intercooler and turbo pre and post and test. should be interesting. I have a WG in the bend just before the turbo flange, does it matter if I put the pressure sensor before or after the WG? Assume It's important to test pre and post turbine rather than just compare downpipe pressure to manifold boost pressure?
