Hesitation under boost.
Old Dec 21, 2016 | 10:08 PM
03sierraslt's Avatar
Originally Posted by Atomic
I have noticed on my blower that boost is not really linear with throttle. Lets say if I just stomp the pedal it will make 14psi, but if I gently roll into it by full throttle it will stay around 7-8psi. I think this has to do with the bypass valve spring not being very strong.
You got something going on then, because that's not normal.
Old Dec 21, 2016 | 10:58 PM
Atomic's Avatar
I have a gauge for that
Like I said, I think its the bypass spring, it has always done that since I first got the blower. Its fine though, if its not making what I want I just let off a little bit then stab it.
Old Dec 21, 2016 | 11:31 PM
flatblack83's Avatar
From what I could see timing fell from 24 to 12.
Old Dec 22, 2016 | 05:26 AM
The # 1 injector plug had to be the problem, the afr was fine and it pulled really good this am...almost too good..lol. Under full boost the afr was low 11s, cruise was about 15s and idles off I guess with the super cold weather 14-16.
I have a new weather pack end and pins to swap on later today. The one I thought had the oring pushing out the connector.
Old Dec 22, 2016 | 05:50 AM
Glad you found the issue.
Old Dec 22, 2016 | 05:17 PM
I'm glad too, i thought it was something else. Atleast it was easy
Old Dec 22, 2016 | 07:13 PM
ZO6Ted's Avatar
Originally Posted by 07Softail
Mine does this also, say im cruising along at 35-40 and ease into the throttle it feels flat and I have to almost make it kick down to get it up into boost. Not liking it right now at all!
RT
No clue but it cant be normal. Mine feels instant and I mean instant. As soon as I blip the throttle while driving it jumps immediately and mine cant be anything special.
Old Dec 22, 2016 | 09:04 PM
07Softail's Avatar
Yeah I don't think it's right either....damn sure doesn't feel right. I was thinking the bypass might have something to do with it. I'm gonna get a boost gauge and a wideband and check it out. Looking for more boost and cubes, Kinda hooked on the torque now. Anybody have any idea what it could be?
RT
