help with turbo id
Old Mar 21, 2006 | 08:18 PM
Default help with turbo id
i got a t3/t4 hybrid off of an eclpise gs today and it needs a new center section. it is a turbonetics turbo. i am not sure of the wheel trims or the compressor a/r. it will not be used for a lsx engine due to its small size. i need help identifying the compressor a/r, trims, and center section.
the numbers that i have found on it are:
side of turbine inlet -- 20357
inside on turbine inlet -- .63
side on compressor -- j1001
compressor end of bearing housing -- 20542
again, i would like to know the compressor a/r, what trims wheels, and who is the best place to get a reman/balanced center section to match both of these housings. i will probably end up putting this on my d/d beretta.
thanks
kevin
kha4079
Oct 29, 2018 04:38 PM
lxcoupe
Sep 6, 2017 08:24 AM
jtphelps289
Sep 11, 2015 06:37 PM
slowswb
Sep 5, 2015 02:27 PM
06murder
Sep 4, 2015 03:54 PM
