help with the HD tensioner from leftcoast32
Old 05-25-2011, 06:18 PM
vicalma03's Avatar
Some pics of his tensioner
Old 05-25-2011, 06:26 PM
11 Second Hall Moniter
AKlowriderZ71's Avatar
Belt is routed incorrectly. Needs to come off the water pump, then to the tensionr, not off the crank pulley.
vicalma03's Avatar
Maybe your belt is to long?? Just a guess...
Old 05-25-2011, 06:27 PM
Originally Posted by TX Tahoe Z71
Did you route your belt like this? The back side of the belt should not be facing the tensioner.
You need to route the belt around the crank and water pump just like in this pic.
Old 05-25-2011, 06:48 PM
11 sec. Truck Mod
TIM Z's Avatar
Yep, Like AK said its improper belt routing. Also why is your tensioner pointing up towards the 1:00 psoition?? It should be closer to 3:00.
Call Joe, he will walk you thru installation, He did for me.
Old 05-25-2011, 06:53 PM
vicalma03's Avatar
Looks like your problem has been solved. It definitely looks like its routed wrong.
Old 05-25-2011, 08:06 PM
03sierraslt's Avatar
Actually AKlowrider's belt is routed wrong and so is anyone's that is routed that way.
Old 05-25-2011, 08:08 PM
terravast4's Avatar
that tensioner can also be set differently by holes in that aluminum spacer....that will bring it to the correct position also
The tensioner assembly mounts to a bracket, there is a pin on one and a hole on the other. There are two holes, I would venture to guess the original poster has his in the upper hole causing the tensioner to sit that way, remove the bolt that holds the tensioner in place and check the location of the pin. If there is two holes move it to the hole to the right.
That's not my belt or my pic, I copied the post from TX Tahoe Z71.
Quick Reply: help with the HD tensioner from leftcoast32
