heatexchanger cooling ideas
Old Mar 1, 2008 | 02:44 PM
Whippled 496's Avatar
Originally Posted by Q8 6.0
now i have new idea i am thinking to slow down water circulation to give heatexchangers more time to exchange heat.. maybe use 1/2 inch water hose instead of the stock 5/8 hose
I think you would want a slower pump, not reduced line diameter. That would result in higher pressures in the system. More volume, slower flow is what you want....not less volume slower flow.
Correct me if i am wrong please someone.
Old Mar 1, 2008 | 07:40 PM
UAE's Avatar
UAE
What about water inj.?
Old Mar 1, 2008 | 11:59 PM
Q8 6.0's Avatar
haha yes smaller hose will increase pressure
maybe thats why i didnt see drop in iat.. maybe i lost alot of pressure with the addition of the new cooler.
cars have high pressure cooling systems = more heat transfer maybe??
help
Old Mar 2, 2008 | 12:05 AM
Q8 6.0's Avatar
hey UAE whats up bro nice to see you here.. im looking for the easy fix first to work on it this weekend then i will look at the water/meth injection stuff later..
Old Mar 2, 2008 | 12:22 AM
stock48's Avatar
9 Second Truck Club
What elevation are you at?
Old Mar 2, 2008 | 12:42 AM
Q8 6.0's Avatar
if you mean how high from the sea? its 3 or 4 feet the whole country is flat i mean really flat there is not even one small hill.. if you stand in the desert you can see the planet curve
Old Mar 2, 2008 | 08:25 AM
t_thall's Avatar
for my air/water intercooler on my turbo setup i tapped a couple 1/2" fittings into my windshield washer fluid tank and have the biggest a/c condensor core i could fit, pumped around with a small farm sprayer pump - seems to work quite well, gotta watch the level in the tank closely though!
Old Mar 2, 2008 | 04:03 PM
Q8 6.0's Avatar
you know for years i have been staring at that AC condenser thing dripping ice cold water on my headers and thinking what a wast cant use it ..
tomorrow i will install metal shields on the sides and top and bottom of the heat exchangers it will come out about 1-2 inch in front so the coming air will hit the metal shields and go thru the exchanger and not just hit it and go over it then maybe install two small fans to pull the air..
i think this will work
Lthompson
Sep 30, 2015 06:48 PM
5.3lSilverado
Sep 20, 2015 06:48 PM
94f150
Sep 13, 2015 06:39 PM
sTNT971
Sep 11, 2015 02:38 AM
carid
Sep 10, 2015 09:07 AM
