headers affect on supercharger
Old Jul 29, 2012 | 03:52 PM
Area47's Avatar
putting headers on make the engine more efficient, which results in a drop in "boost" levels. putting too much on "what happened to my boost" vs "hey, i just picked up 40hp and the iat's are a lot cooler" id chose the latter of the two.
Old Jul 29, 2012 | 04:20 PM
ou812sm's Avatar
So if my thinking is correct get the headers and a pulley to gain about 3# more I should be safe and the gain will be good as for the cam I'm still in the air on it
Old Jul 29, 2012 | 05:19 PM
03sierraslt's Avatar
Just make sure you get it tuned when you add the boost etc.
Old Jul 30, 2012 | 09:02 AM
TX Tahoe Z71's Avatar
Also make sure you have enough fuel pump and injector to support more boost.
Old Jul 30, 2012 | 10:19 AM
Yes very true
Old Jul 30, 2012 | 10:45 AM
Boober's Avatar
What pulley are you getting for your Whipple, if it's the standard 3-5/8" pulley, you'll be lucky to see 6psi, less if you're running LT's. The 3-3/8" pulley will make about 8psi with LT's and 9psi without. I actually didn't gain much with the LT's but I'm still working on my tune and I'm waiting for some cooler temps.
Old Jul 30, 2012 | 11:18 AM
Pretty sure he has a 5.3.
Old Jul 30, 2012 | 05:17 PM
Boober's Avatar
I think, in the cam thread, he said he has a 09' Denali with the 6.2
Old Jul 30, 2012 | 05:26 PM
ou812sm's Avatar
Yes 6.2 denali
Old Jul 30, 2012 | 05:45 PM
AndysC3's Avatar
I would install the blower and exhaust and see what boost your running. Then run the pulley needed to get the desired boost level.
