having a few issues can someone lend some advice
Sounds like you have checked everything out thoroughly. Not sure if the fuel issue is related to the vacuum problem. Could it possibly be that the cam is a little agressive for the 4.8 and vacuum is dependant on rpm? As far as the fuel issue maybe it's the tune. I'v herd horror stories about idle tuning larger injectors. Sorry I couldn't be more help, good luck.
Running 6-8lbs of boost on a cammed 4.8 motor, you shouldn't require the 60's. Is there a reason you went with the larger size rather than 42's (like what comes with the Magnuson kits. Same boost levels as a maggie)
That might be a starting point.
Is the regulator "boost referenced"
I also agree with Old Bull, you might want to "cam-down" a little for that 4.8
Wheel to Wheel did a stock 4.8 with 42's, a 67 mm inlet Garrett and 8 lbs boost and got 542HP at 5,100 RPM/603tq at 4,500 (engine dyno)
8 psi on this setup isnt the same as 8psi on a moggie. yes regulator is boost reference. again its the 2K hp model. i dont remember part number off top of head.
well i believe i found alot of my issues. first thing i noticed. i pulled my old injectors and yes a few were dripping. these i bought off ebay claimed 60lbers... they ohm'd out to be 12 for a reading. so i borrowed a set of 42s for now. they ohm out to be 16 these are bascially brand new. i installed these and didnt see any drips. but pressure did drop again. when i took rail off i noticed i still have fuel in the rail that the regulator was mounted to. well i went over entire feed and then took it part. i pulled filter apart and notice debris in the screen. i also notice some real small particles that might of went thru the screen. [might have clogged injectors]. well i cleaned filter and noticed the liquid i was pouring thru was coming out other side of my line. so i tore it part at the checkvalve. and noticed the flap didnt seem right. cleaned that and tested. yupp it leaks. tore it apart and tried again. again it leaks. it holds air one way but doesnt hold liquid. so my bleeding off is from the walboros and the earls check valve not working so i wasted money with this product. [over winter going ot make some changes now]
next issue to address. see if the spike hurt motor....
did a compression check and motor reads as follows
1=150 2=145
3=145 4=145
5=150 6=145
7=150 8=145
these were all done with a snap-on gauge
ok next test was a leak down. so i started pulling valve cover off to check for valves being bent again and good. as i noticed i pulled the booster line and i had vaccum on this [good sign]
so did a leak down and this motor is claimed to be a 7k mile motor
1=2% 2=1%
3=1% 4=1%
5=1% 6=2%
7=1% 8=1%
guess motor checks out. so tomorrow going to toss plugs back in and give it a try again. i believe my fuel issue was the bad injectors....least motor is sound
1=150 2=145
3=145 4=145
5=150 6=145
7=150 8=145
1=2% 2=1%
3=1% 4=1%
5=1% 6=2%
7=1% 8=1%
gaps
Oct 15, 2015 02:53 PM
murderedSS
27
Oct 12, 2015 11:13 AM
MA$TER_E
Sep 9, 2015 03:14 PM
