guys with FMIC's
Pick an intercooler that is just slightly above your horsepower goals. Too big will give pressure loss, slower spool up, and greater turbine pressures to acheive your desired psi which can hurt your power more than help it. Thickness needs to be moderate,but not excessive as the drag coefficient goes up as thickness increases. A intercooler with 35 sq. in of internal flow area will support 700 cfm of flow. You calculate internal flow area this way. (internal flow area = Channel length x channel width x number of channels.) Most intercoolers have only a 45% availibilty of flow through the cores. What are your hp goals and what turbo?
Truck Sponsor
Originally Posted by MikeGyver
Yeah, it still has A/C. Check my install pics.
Rick
Sorry, I'm so egotistic that I think that everybody knows the intimate details of my I/C install. I made brackets and used electric fans to move the radiator back about 2 1/2 inches. I moved the condenser back as far, and installed the I/C between the condenser and the hood latch support. I cut and capped the discharge of the Whipple, and fabricated a right-facing discharge. I made a new left-facing intake elbow, and piped the I/C in.
My temperatures are similar to 03sierraslt's, so my intercooler is probably too big. Except what does that mean, since I have no throttle lag?
Anyway, I'm sure that it will be capable of more boost, except the blower isn't.
The guy on eBay gave me a discount if he could use my pictures. I kept telling him it wasn't finished, but he didn't care. Real nice guy, by the way, if anybody is thinking of buying from him.
i found that one and it says 1,000hp and its $100 cheaper than the big one i may just go for it instead. pressure drop doesn't seem to bad.
Length 31" (600mm)
Height 12" (300mm)
Thickness 4" (100mm)
Inlet 3"
Outlet 3"
Compress Air Flow Rate <800Cubic Feet/Min, Rated up to1000 Max HP
Working Pressure: 40~45PSI
Pressure Drop 2~5psi@35psi; 0.2~0.5psi@15psi
Hot Air Temperature 32°F~302°F (0°C~150°C)
Material 100% Aluminum
Design Bar and Plate
Construction Machine Cut and Stamped, Hand Welded
Finish Polished
Net Weight 24lbs
Works for Many Cars and Trucks
Length 31" (600mm)
Height 12" (300mm)
Inlet 3"
Outlet 3"
Finish Polished
Net Weight 24lbs
