Guess on 1/4 mile time?
Ill be runnin my truck friday night jus to see what it will do...
07 classic rcsb
4.8
Ls6 cam
S366(9psi)
Stock trans& converter
3:42 rear
30" tire
No idea of power output this willbe the trucks first pass on the track
Any estimates
Thanks
07 classic rcsb
4.8
Ls6 cam
S366(9psi)
3:42 rear
30" tire
Any estimates
Thanks
Depends on the tune and if you build boost at the line and can hook. It has potential to run high 11 or very low 12 in cool weather but hot weather and with the stock converter probably mid- low 13's. Gonna be fun!
07 Classic 4wd rear mount ran 8.9 1/8 (~13.8-13.9) on 5.5 lbs with 4.10's & 32's and I was able to leave at 2300. Same as your 30" tire with 3.90's. 8.5 lbs in hot weather 8.11. Cold weather with no changes 7.64. I think you'll be impressed if it will spool quickly. Good luck Blackrat!
