GT11 cam on L92 with 2300 Maggie?
I came across this cam. What's the opinion on the combo? L92 with CNC LS3 heads, and a 2300 Maggie. Would I notice much of anything switching to the GT11 cam from my current cam(224/230 .609/.612 116+2). Thanks
Would there be any power gains with the GT11 when I do install blower?(might be my 2900 to test out).
Btw I hear YOU might be going the whipple route?
Decisions, decisions. So if I stayed N/A it would be rougher on the valve train, but have better street manners and more TQ than what I have?
I ran a 215/227 116 with LSL lobes under a TVS2300 for quite a while and liked it. Wanted something bigger....stupid me. Wished I still had that cam. The GT11 won't give you any power gains over your 224/230. Smaller gets you better manners and fuel eco. Bigger is better (up to a point) on the dyno.
Still investigating the Whipple 2900 swap on my vette. We'll see.
Nothing wrong with the GT11 cam other than it uses Comp's LSK lobes. Crazy high lift that's needlessly hard on springs. If you like those specs, you can have the exact same cam ground on Comp's newer design, and easier on valve springs, LSL lobes. Same specs, just a more stable lobe with a little less lift. If you call Comp tomorrow and ask for a custom spec recommendation, I'll bet you just about anything you care to lose, that they won't spec you a cam with LSK lobes.
I guess the GT11 will be for sale soon
