Green spark plug strap...
I was seeing the misfiring at 18psi+ but not below...and yes they had some idle time after the high power run, so its obviously not the best case to read plugs...it was never lean.
There is no "TR7", but the plugs I have are a "7" heat range copper plug by NGK, the BR7EF. I am going to try the 8 heat range next....but if the green strap is that common the misfire issue might be unrelated...
