Good Cam for force induction
Old Jul 13, 2008 | 11:35 PM
UAE's Avatar
UAE
Default Good Cam for force induction
Looking for a good cam to go with my Supercharge Denali 6.2 with stock internal.
I prefer smooth idling
Old Jul 14, 2008 | 07:45 AM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
With FI, you want 0* of overlap (or close to it). A supercharge needs an exhaust bias that's decent sized.
Take a look at things like:
Comp Cams XR269HR-14 : 218/224 .527/.534 114lsa
Or a 2002 Z06 cam
Old Jul 14, 2008 | 08:17 AM
stock48's Avatar
9 Second Truck Club
A ISKY 212-221@.050, .561''/.575'' on a 115* would work well. Like said above the Zo6 cam wouldn't be a bad choice either, it would have a little smoother idle, but I think the ISKY would make more power.
Old Jul 14, 2008 | 08:41 AM
I AM A MOTHERF*CKER
Ohhh. I like the looks of that Isky.
What are the stock springs good for? I was thinking .550.
Old Jul 14, 2008 | 09:01 AM
Wilde Racing's Avatar
How do I change this text
not when the intake valves have got boost pressure on them...
Old Jul 14, 2008 | 09:09 AM
I AM A MOTHERF*CKER
Well, see, you just use the pistons to nudge them back closed.
Old Jul 14, 2008 | 09:10 AM
Hawk179's Avatar
Or a 2002 Z06 cam
You should rephrase that by saying you want a cam with little overlap since every cam has overlap in it. Its how much you want and are willing to put into a setup that matters.
R
Old Jul 14, 2008 | 09:14 AM
I AM A MOTHERF*CKER
What about all those cams with negative overlap?
BTW, the '(or close to it)' covers me. I had my lawyer check it out.
Old Jul 14, 2008 | 09:33 AM
Hawk179's Avatar
To say negative overlap is not really true. The only overlap that stays constant is that at seat timing. The negative overlap you are talking about is the value @.050.
You should always look at the overlap at .006 as well.
R
Old Jul 14, 2008 | 10:14 AM
SincalT/A's Avatar
I am going to recommend a crane low lift 212 218 531 531 114 if you want to go a off the shelf route.Only cause I know that particular motor seems to work well with that camshaft.
Or go with a custom grind maybe speced by rick if you want.It may cost a little more but,probably work better for you.
What ever you get don't worry about bigger duration higher lift a smallish cam under 220 duration and 550 lift on both ends.Keep lobe sep. in between 114 to 116 and you will get by just fine.
