Going with Livernois...questions??
Old Mar 1, 2006 | 11:29 AM
Default Going with Livernois...questions??
After buying the kit, what else is needed? Tune, plugs, etc...thanks
Old Mar 1, 2006 | 02:08 PM
XLR8NSS's Avatar
Adkoonerstrator
Tune is it. It comes with new plugs, wires, and fuel injectors. Once you start modifying beyond the stock setup you may have to address the fuel pump also but, the stock pump is ok even with slightly modded setups.
Old Mar 1, 2006 | 02:12 PM
That sucks. I just changed the plugs and wires last weekend.
02sierraz71_5.3's Avatar
might consider a 2bar map its fairly easy to max the maf and your tuner will love you for having it setup allready so he can tune for boost.
Old Mar 1, 2006 | 02:19 PM
Thanks
Old Mar 1, 2006 | 06:25 PM
Mort's Avatar
Cool
Boost and Fuel Pressure Gauges.
Old Mar 1, 2006 | 09:55 PM
What kind of times can I ecpect to see? The last time I ran the truck was in the 1/8(only track I have been to) and it ran a 9.3x. That is pretty much stock. No major upgrades or anything
Old Mar 5, 2006 | 09:21 AM
OnyxSilveradoSS's Avatar
you will need to get some heat shielding for stuff underhood temps get high and This is the one area that I think Livernois has not addressed. You might inquire about the upgraded turbo???
