Garrett GT30
Old Oct 12, 2008 | 09:02 PM
Started the buying process for my turbo setup today... heres the blow off valve and turbo charger.
comparison of 2 turbine housings. the bigger one (1.06 A/R) came mounted as you can see...the smaller one is a .82 A/R
aaaand i got trigger happy (inside of compressor)
!!! im excited... pics of wastegate soon
Old Oct 13, 2008 | 12:11 AM
rockerjoe2008's Avatar
When I talked to STS about a remote system they recommended that I run a small intercooler. I think an intercooler could only help and give you more power via colder and denser air.
Old Oct 13, 2008 | 01:09 AM
right on thank you for your reply! you know what though? ive decided to spend the extra money on a custom turbo manifold so im gonna go with a custom upper front mount kit! i'll keep this thread updated with pics. I have a question though for the turbo dudes. For water and oil feed lines to and from the turbo. where did you guys get them and whats the best quality/brand? and what pumps did you use if any?
Thank you!
Old Oct 13, 2008 | 01:31 AM
good call getting the manifolds done. get something installed to pull a little timing when you're in boost. have fun. oh, and that's not even close to being too big for your application. stick the .82 a/r on it for spool. should be almost perfect.
Old Oct 13, 2008 | 02:08 AM
right on. thank you! yeah i'll be getting an MSD BTM to do the retarding ... what do you suggest for oil/water feed lines?
Old Oct 14, 2008 | 04:06 AM
aaaaaannnnyyyyybboooooddddyyyy??
Old Oct 14, 2008 | 04:20 AM
nemmarick's Avatar
seems how u have the money to spend on a nice turbo build, a built to order custom length return lines seems like right up your alley should be minute compared to the custom turbo manifold u had built
Old Nov 20, 2008 | 03:02 AM
so i swapped the GT30R for a GT35R
extra turbine housing 1.06 A/R
Vortech FMU
Autometer Boost gauge
the turbo manifold is getting fabbed this weekend, still have vacuum line, intercooler, and an extra fuel pump to buy
soon shell be good to go!!
Old Nov 20, 2008 | 03:17 AM
The specs for this turbo are...
compressor ind:61.4 mm, exd:82 mm, 56 trim, .70 A/R
turbine is 68mm, 84 trim, have a .82 A/R and 1.06
the turbine mounted to the turbo is the .82 A/R
Old Dec 23, 2008 | 02:34 AM
some updates... got the intercooler and the turbo manifold ceramic coated
the coated turbofold matches pretty good with the coated JBA header hmm?
intercooler
I will be doing the full install this friday and saturday
