Fuel system??
Old Dec 8, 2008 | 12:44 PM
MikeGyver's Avatar
I should let you proof read my posts, you can say in two sentences what took me all afternoon to put into two paragraphs.
Old Dec 8, 2008 | 03:12 PM
4.8 truckin's Avatar
I think it is a great idea. Do you think you might still get air on the line if the main fuel tank bung becomes un covered or would there be enough in the sub tank to stop this from hapining
Old Dec 8, 2008 | 03:28 PM
Originally Posted by Mort
I have an '03 with the return system. I added an inline 255LPH Walbro. But even so, with less than 1/4 tank, the fuel will be forced to the back of the tank on a WOT run and starve the in-tank fuel pump. The bucket does not hold enough fuel to feed mine for a 12 second run if the tank is < 1/4 full. It will run dry before I reach the top of 2nd gear and miss like a ****.
Ya i dont want that. does the higher flow inline pump possibly starve the in tank pump too?
Old Dec 8, 2008 | 03:33 PM
MikeGyver's Avatar
That's the idea, I think I read somewhere that a 500 HP engine uses about a gallon per minute. A quart should supply it for about 15 seconds, if you are going full throttle in reverse, or somehow using full power and braking while going forward(?).
If you are braking with your foot off of the gas, a quart will be plenty.
Old Dec 8, 2008 | 04:14 PM
Mabe there is a way to put a baffel or a sump were the fitting is going to be. I know im not going to be doing any full throttle blasts in reverse, but that could be alot of fun lol
RONIN LSX
Aug 10, 2015 04:45 PM
TAPyvehc93
Aug 8, 2015 06:35 PM
MS3Z
Jul 30, 2015 06:17 PM
4B11T
Jul 13, 2015 03:48 PM
