Fuel Pump Problems Possible?
Old Sep 16, 2010 | 08:35 PM
ccantu0389's Avatar
Default Fuel Pump Problems Possible?
Well guys after having my TVS 1900 installed on my 08 Sierra (about 3-4 months now) I was told I would not need a fuel pump, but today I started the truck up and it died off on me after starting it up again the rpms went up a little and the truck started idling a little so I accelerated a bit and it seemed to work just fine, it's only done it about 2 times and seems to be working fine after that, the fuel pressure gauge is reading 45-50 psi and it seems low to me for a reason? Could it possibly be a fuel pump issue? Or maybe some type of wiring?
Old Sep 17, 2010 | 12:21 PM
PediDr2's Avatar
If it died you had an issue with Fuel, Air or Spark. I know, Duh.
Does your fuel pressure fluctuate? Can your pump keep up.
Has it happened again?
Old Sep 17, 2010 | 04:30 PM
ccantu0389's Avatar
Well it's happended about 3 times, whe the truck is started the Fuel Gauge read 60-63 psi, but after being on for a bit it goes down to 45-50 and just plays around in that area, i doub it's the gauge messing up.
Old Sep 22, 2010 | 02:12 PM
z71xl's Avatar
I'm having the same issue with mine...fuel pump is only showing 6.3v at 60psi and 5.1v at 44psi which seems way 2 low! Really hope someone can come up with a solution!
Old Sep 27, 2010 | 09:47 PM
ccantu0389's Avatar
Yea I'm sure that's the problem, bought my 255...It should be going on this week and hopefully tha'll solve the problem.
slowlsx
Aug 13, 2015 08:28 PM
roprisiu
Aug 9, 2015 10:47 PM
05GMC4.8
Aug 7, 2015 09:55 PM
MS3Z
Jul 30, 2015 06:17 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
