Fuel pressure at idle w/ supercharger
Old Jan 11, 2018 | 05:49 PM
About20ninj45's Avatar
Default Fuel pressure at idle w/ supercharger
Question. What are you guys fuel pressure at the rail with the supercharger at idle?
Would also like to know fuel pressure at idle for vehicles with the flex fuel pump from 99-2007 classic
Old Jan 11, 2018 | 05:54 PM
FFDP's Avatar
GMT-800's were designed to run at 58psi.
The later model trucks can vary in pressure with computer control fuel pump modules.
Old Jan 12, 2018 | 04:17 AM
madmann26's Avatar
At idle it should be stock pressure.
You're not building boost at idle so pressure will stay the same.
Old Jan 15, 2018 | 03:50 PM
Fullpower's Avatar
my 2002 flex fuel has STOCK fuel pressure regulator:
static pressure, key ON at 58 psi.
Idle FP is around 52 psi.
Highest I have noticed is about 68 psi on heavy throttle.
Old Jan 15, 2018 | 03:53 PM
Just wanted to confirm my readings, my fuel gauge was leaking at the fitting and iI need to know what koeo, and idle pressures should be. Thanks guys...
I'm too afraid to keep it running until I can figure out how to stop this leak from the screw on fitting on the rail.
dirty_old_chevy
Aug 16, 2012 05:47 PM
phasemaster1
Nov 12, 2008 09:40 PM
CashDudeHomie
Jan 6, 2008 02:39 AM
