forged pistons = increase boost ?
Old Feb 22, 2007 | 12:45 PM
fairline's Avatar
Default forged pistons = increase boost ?
Actually i just rebuilded my h2 hummer 6.0 engine which is iron block to -13.7cc forged pistons and good rings also iam using the stock rods but inforced them with APR bolts ,
i was only running 5 psi sts turbo with Garret 67 when the engine was stock
the question is
what would be my CR with my forged pistons am using . the piston bore is 4.00 using the stock rods with apr bolts
would i lose hp in dyno if am still running 5psi with the lowered compression?
what hp would u think it will be my max , i have on hand 7.2 psi & 10 psi springs am getting hard time to decide which to use
car is heavy it has 3600 stall converter, GT7 camshaft lingenfelter, stock manifold
transsmision is well built
your answer will hopfully save me alot
Old Feb 23, 2007 | 01:39 PM
fairline's Avatar
52 views no single answer ? lol thanks any way
have a good day
Old Feb 23, 2007 | 02:09 PM
Ruffrider5.3's Avatar
Put the 7 lbs spring in and let it fly. Yeah it will make a little less power due to the pistons, but you put them in to use them right? Put the 7 psi spring in and tote it over to the dyno and get it tuned. Take the 10 psi spring with so you can slap it in when your done with the 7 pounder. Not sure on the comp ratios with that setup.
Old Feb 23, 2007 | 02:25 PM
TurboGibbs's Avatar
You are right at 8.8:1 if you are using stock MLS gaskets that are .052" thick. .040" gaskets will give you 9.0:1. With compression that low and a really good custom tune you could safely run as much as 14-15psi on 93 octane if it is intercooled. Hope this is what you were looking for.
Old Feb 23, 2007 | 04:41 PM
fairline's Avatar
thanks am gonna use stock gaskets going to tune it at 7lbs then going to slap it to 10lbs soon , will post pictures soon , thanks for the comments guys
GMCtrk
Dec 18, 2015 04:47 PM
zachman078
Sep 21, 2015 04:36 PM
JordanH
Aug 8, 2015 07:59 PM
black6spdz
Jul 16, 2015 01:32 AM
kdw8888
Jul 9, 2015 10:52 PM
