forced induction/referenced FPR. Tuner says leave it unhooked. WTF
Old Apr 12, 2022 | 09:59 PM
Atomic's Avatar
I have a gauge for that
Originally Posted by jon1440
should I mount booth shocks behind the rear?
It does help and looks cool. I highly recommend this kit: https://atomicfabandperformance.com/...ear-shock-kit/
Old Apr 12, 2022 | 10:01 PM
shakenfake's Avatar
Shlumpt
5 Year Member
I have relocated shocks with no traction bars. Hooks wonderfully.
Old Apr 14, 2022 | 11:12 AM
jon1440's Avatar
Im going to be adding 2" drop shackles in the rear to get the ride height leveled. So I called Belltech and would think they would know what shim to use to get the pinion angled back to stock. They say to install the shackles and then figure it out. I guess the million trucks like mine produced have random suspension parts during the production. Its clear if the pinion was set correct from factory and now pointing it down after adding drop shackles I'm going to assume I'll need some sort of shim.
Anyone know what degree of shim is needed?
I've been trying to find out a good setup for what I'm trying to do but seems like people are doing a multitude of different things. I should be able to use leaf springs with the traction bars I have. I'm not sure if I need to keep all the springs or if it would be better to remove one. The truck doesn't squat much so trying to get the rear momentum under the front half of truck isn't working. I haven't been down this road before so I'm just trying to find what works.
The shocks are still stock which are probably completely junk. So, new front shocks will be installed and I'm thinking on those they need to be able to let the front of the truck rise up more freely.
Old Apr 15, 2022 | 11:18 PM
RDF1's Avatar
DuNnO
5 Year Member
Ive got this link saved on my phone and send it to all these guys that want me to work on their trucks. Fits perfect and very easy to weld on.
Old Apr 17, 2022 | 12:09 PM
03sierraslt's Avatar
Without a doubt use the referenced regulator. Yes you the. Have to flatline your injector tables (IFR, offset) No you don’t flatline VE. Lower the rear and then check angle. I am lowered 4” in rear and mine still good, but I have a different trans mount and Dana 60 rear so not apples to apples.
brandon6.0
Feb 8, 2013 02:32 PM
bigboy576103
Dec 20, 2011 06:20 PM
Swerve7rpm2000
Dec 17, 2011 12:54 PM
$nake Charmer
Sep 6, 2011 07:23 PM
kalikid06
Mar 28, 2011 11:51 AM
