Which flexplate for the high HP 80e guys?
#21
I'm not aware of any flexplates that are significantly lighter than stock. I was fretting over the fact that the TCI flexplate was 2 lbs heavier than the CDS Reactor plate until I remembered that I was losing approximately 30 lbs of rotational mass with the aftermarket converter versus stock.
#22
Haha good point!
I'm also a little amazed by how most people seem to avoid many TCI products in many cases, but here quite a few are running and recommending the flex plates.
#24
Anyone know of a cost-effective flexplate for a Yank 80E converter? I believe their 80E converters have a 6 bolt pattern. Would this one work? LS1 SFI FLEXPLATE
#26
#27
I'm hoping to find a flexplate that will bolt to an 80E and not require a spacer. Perhaps this is only possible when using a converter that has an 60E bolt pattern like Circle-D.
#29
I found this Hughes flexplate, but it shows this adapter as a "required part". Anyone know about this flexplate?
http://www.summitracing.com/parts/hup-hp4004x-ebp
http://www.summitracing.com/parts/hup-hp3795
#30
Yank says their SFI flexplate is only for 60E applications. Their multi-disk units only come with a 6-bolt 80E bolt pattern and thus need an 80E flexplate with spacer. They recommended using TCI 399754 with their multi-disk 80E converter.
