Which flexplate for the high HP 80e guys?
Old Nov 15, 2013 | 10:37 PM
JoeyGC5's Avatar
I have the Circle-D sfi flywheel. Chris had a good deal on it when I had my converter restalled. The Yank sfi flywheel was cost effective also.
Old Nov 15, 2013 | 10:44 PM
DrX's Avatar
DrX
Originally Posted by GMCtrk
Why did you switch from the TCI? The billet piece saves roughly 1.25 lbs versus the Steel piece. Otherwise I can't come up with any other reason for the extra $100+ on the billet.
I don't think there was anything wrong with the TCI other than a trans builder recommending the Meziere after the trans failed.
Old Nov 18, 2013 | 11:11 AM
Vortec350ss's Avatar
I need to pull the trigger on this today... anyone have a part number for me on the TCI?
GM LS1 168-Tooth Internal Balance Flexplate - TCI® Auto
Is that one it?
Old Nov 18, 2013 | 11:16 AM
GMCtrk's Avatar
For 4L80E applications, use P/N 399754. That's the one that will have the crank spacer and 6 converter bolts.
Old Nov 18, 2013 | 11:25 AM
Awesome. Thanks
Old Nov 18, 2013 | 11:35 AM
chevrolet all the way's Avatar
i run the circle d and have ZERO complaints
Old Nov 18, 2013 | 12:02 PM
TCI was ordered... better safe than sorry.
Thanks for the help guys.
Old Nov 18, 2013 | 12:13 PM
timmay208's Avatar
depends on what tq converter you will be using. im gonna use the Circle D converter for my 4l80 that uses factory flex plate so in a case like that have to order stock flex plate
if you are using 4l80 converter then you want 4l80 flex
Old Nov 18, 2013 | 12:37 PM
Atomic's Avatar
I have a gauge for that
I use the TCI one as well. The converters I have used in the past have a muli-fit front cover (has 3 different bolt patterns on it), so the 60e plate works fine.
Old Nov 25, 2013 | 09:48 PM
ShredSled's Avatar
Does shedding weight on a flex plate actually result in quicker revving like a lighter flywheel? Just curious, never swapped flex plates before but have had cars in the past that I put lighter flywheels in and loved the result.
