FI and transfer case?
Old Aug 14, 2011 | 08:33 PM
  #21
TIM Z's Avatar
11 sec. Truck Mod
Originally Posted by AKlowriderZ71
My truck stays in 4hi for the entire pass. It won't shift out until I left.
Tim, I was just trying to give you a hard time buddy.
I know Roger, i was just trying to get some thoughts/discussion on the 4x4 engaged the whole way down the track .
My truck feels fine when i do it, but like i said most of the time i hit 2 hi after launch and always wandered if im hurting anything.
Old Aug 14, 2011 | 09:36 PM
  #22
black04's Avatar
I've had mine in 4hi before up to 110 and no problems.
Old Aug 14, 2011 | 11:47 PM
  #23
DrX's Avatar
DrX
I used a NVG246 out of a factory equipped 80E truck when I did my 80E swap. Looks identical to my original NVG 246, but the HD t-case got a 6 pinion planetary set vs 3 or 4(depends on model year) in the 60E trucks.
I've had no problems with the t-case. Mind you I usually stay in 2 WD due to the weak front driveline. Transmissions are another story though.
Old Aug 15, 2011 | 06:16 AM
  #24
sureshot's Avatar
I heard the 60E t-cases had 3 or 4 planetary sets as well. When sharpshooter and I did the input shaft swap on our t-cases, they both had 6.
Old Aug 15, 2011 | 06:47 AM
  #25
russellisabel's Avatar
sureshot how do you like that circle d converter? is it a single or triple disk? im going to order a triple disks one from them at 3300stall so it will lock at wot. im currently useing a yank sc 3300 single disk. also good point on the shaft ill be checking in to that this morning seeing as the tranny is out and ready to go while i wait for the converter (ordering today) ill see about getting that shaft swaped. lots of good info here. i like getting info from guys who have actually done it.
Old Aug 15, 2011 | 08:39 AM
  #26
DrX's Avatar
DrX
Are yours' the NVG246 with the 4 button switch? I'm going by the GM info for the 246 up to 2005. Don't know what they did after that.
"There are two versions of the NVG 246 EAU, which depend on the transmission applications and vehicle applications. If the vehicle is equipped with a transmission RPO M30, the transmission splines in the input gear will have 27 teeth. With this application the planetary carrier assembly will have 3 pinion gears. If the vehicle is equipped with transmission RPO MT1 or MN8, the transmission splines in the input gear will have 32 teeth. The planetary carrier assembly on this application will have 6 pinion gears. "
Old Aug 15, 2011 | 08:56 AM
  #27
sureshot's Avatar
The converter was awesome, it would flash to about 3000, but was still efficient up top. It's a single disc.
Old Aug 15, 2011 | 09:00 AM
  #28
sureshot's Avatar
Yup, it has the 4 button switch.
Old Aug 15, 2011 | 10:32 AM
  #29
mine is a 2006. i just checked under the truck and the tag says 246 a man# and ser# cant fine either code you mentioned. how would i know what m-code i got? where do i look? i also have the 4 button switch however i know that my 2006 was the last year body style and they switched in 2007 thus my cpu is'nt like a 2005, or a 2007 its kinda split verision of both so i ran into some tunning issues thats how we found out. so i might have a m-code for a 2005 or a 2007. glad you brought it up. so how do i find out?
Old Aug 15, 2011 | 10:36 AM
  #30
black04's Avatar
I wouldnt worry about the transfer case. Itll take a lot to break it. Worry more about the output shaft on the transmission.
