FI guys running breathers/no pcv. How's your oil look?
Old May 27, 2013 | 09:42 PM
kelsey_canard's Avatar
Default FI guys running breathers/no pcv. How's your oil look?
I have been planning on running a breather and no pcv for my turbo build. Then I remembered a buddy who had done this and ran into a little water in his oil. Do you guys running breathers have to change the oil like every 500 miles or does it stay pretty clean? I can deal with the smell of breathers, but I dont want to have to a large amount of contaminants in my oil. I've read enough pcv threads to make me sick.
Old May 27, 2013 | 09:46 PM
Chevy_King1500's Avatar
i have an upgraded check valve for my pcv. throttle body is capped and a breather on the passenger valve cover..
i haven't done an oil changed since i've been boosted.. (dec.) i should probably do that soon, maybe this weekend
Old May 28, 2013 | 09:07 PM
Alpinestar's Avatar
Yea your oil will get dirty faster but I've never had an issue with water in my oil. I probably go about 4k miles between changes with mobil red cap. Just depends on how hard I've been driving it.
Old May 28, 2013 | 10:23 PM
Ferocity02's Avatar
Just run the stock PCV system (with a catch can and check valve inline) and a breather on the passenger side valve cover. Unless you're using the MAF in which case it gets a little more difficult as all ingested air should be passing through the MAF first, otherwise it's a glorified vacuum leak. This is what my tuner told me.
Old May 29, 2013 | 08:01 AM
Thanks for the responses everyone. I think I'm going to just run a breather until I can get a pcv setup I'm happy with.
Old Jun 1, 2013 | 12:57 AM
Atomic's Avatar
I have a gauge for that
I just run a breather...oil looks fine. Yes there will be a small amount of water in the oil, however this will quickly evaporate once the oil gets up to temp.
fillpot
Jul 26, 2015 07:21 PM
dantheman1540
Jul 24, 2015 01:50 AM
lxcoupe
Jul 21, 2015 02:12 AM
dantheman1540
Jul 18, 2015 01:13 PM
kdw8888
Jul 9, 2015 10:52 PM
