Few Questions on a newly boosted application
Piss Pumps for Sale
From: Moncton, New Brunswick, Canada, The True North Strong and Free!
Well any day now my complete kbracing intercooled turbo should be arriving. Its a an intercooled kit like I mentioned, t78 turbo, Tial 44mm waste gate and tial 50mm blow off valve. 3.5 inch down pipe.
Anyways my truck is a 2011 5.3 flexfuel, A6. So Im sticking with the stock flexfuel pump for now, but I dont know what to do for injectors? Can someone point me in the right direction?
Plan on going with br7ef plugs gapped at .028, anything else I should look into getting? truck is stock besides a wheatley tune and corsa 3" catback
Bosch EV-14 Injectors.... Got mine from fuelinjectorconnections.com....They are a direct fit 60lb injector....Stock flex fuel pump should be fine for now...
http://fuelinjectorconnection.com/sh...&productId=171
Piss Pumps for Sale
beautiful! exactly what I was looking for, thanks man
Wait.....48mm o ring to o ring, thats only 1.9 inches, I dont have anything to measure with atm but isnt the stock flex fuel injectors longer then that?
They may have changed in 2011 but mine (for a 2010) were short like the ls2 style...I didnt' have to modify anything!
I called fuelinjectorconnections and they new what I needed! And super fast shipping....
Be sure the injector you buy has data available,if they do not then I do not recommend buying them!!
The injectors Dusty mentioned work well,they usually include data with them if needed.
Piss Pumps for Sale
what do you mean by data?
Also it ask to specify 4 bar at 60lbs an hour or 3 bar at 60lbs an hour, whats the difference and what do I want?
data is what a tuner uses to define the injector characteristics in the tune. bar,in this case, refers to what fuel pressure your using. most modern gm stuff uses 4 bar but you can use 3 bar if you know the data and have a adjustable regulator.
