excessive smoking out of vent on valve cover after a pull.
Old May 18, 2015 | 11:53 AM
Atomic's Avatar
I have a gauge for that
Yep, pretty normal, generally speaking. Performance engines tend to have more blow by so they survive at high power. Just the nature of the game until someone comes out with something better than rings to seal the pistons.
Old May 18, 2015 | 12:35 PM
darkirish63's Avatar
Are we talking a pretty much stock bottom end or something built for boost? Just curious...
Old May 18, 2015 | 11:44 PM
idahoblkss's Avatar
its a forged 408 built for high boost. well i think its a good idea to do a leak down test anyway to be sure and hopefully for just peace of mind.
Old May 19, 2015 | 07:07 AM
Atomic's Avatar
Leakdown tests are good, but they are more useful if you do them over time, especially when the engine is brand new so you get a baseline for your engine using your tools.
Old May 19, 2015 | 07:15 AM
George C....'s Avatar
Formerly ScreamingL
you say built for hight boost, do you have 1/2" head studs? do you have I beam rods? and what are the ring gaps?
one definition for high boost may not be same as another persons
Old May 19, 2015 | 10:19 AM
idahoblkss's Avatar
good point.
so unless the motor is built with 1/2" studs and i-beam rods its not a high boost motor ? thats about as ignorant as it comes ... i placed an order with my engine builder and told him exactly what the motor was intended for . i told him i was planning on 25 psi at over 1000hp was my goal so he recommended certain things like upgraded rings, ARP everything and a couple other things. he was quite confident the motor would be fine up to 1300+ hp so i would consider that to be a high boost motor. is it an extreme all out build made for a drag truck thats making 2000hp , nope. but i would say at 25psi its made for high boost.
Old May 19, 2015 | 10:53 AM
Formerly ScreamingL
good point.
ignorant is not knowing what happens with cylinder pressures of a 4" stroke
if that motor did make a TRUE 1300 rwhp without pushing a drop of coolant or busting the rods id buy it off you
ask blown06 how his motor handled that amount of boost? he has spent a assload just to make his 4 bolt motor keep from pushing coolant
stock stroke is a whole different animal for cylinder pressure
Old May 19, 2015 | 11:36 AM
idahoblkss's Avatar
ignorance and not knowing because of lack of experience are two different things. ignorance is saying that unless you have 1/2" studs and I-beams you dont have a motor built for high boost . ill go turn down my boost then since it cant be done according to you since my motor is built for LOW boost because i settled for standard ARP studs and forged H beam rods.
Old May 19, 2015 | 11:44 AM
Formerly ScreamingL
not reason to turn this into a pissing match, your motor wasnt built for big power...Also dont have the parts to support that kind of power either
big power isnt cheap, 1000rwhp isnt big power in 2015 when stock motors handle that
what limitations of parts comes into play....a proper 408 with a turbo or turbos capable of 25 psi will make north of that 1000 mark. That is when you find the limitations for 4 bolt stuff with standard head studs or block prep
even at that power level with a 6bolt setup if the tuner isnt aware of things motors will fail
all this comes from experience and you just took it the wrong way
Old May 19, 2015 | 07:32 PM
zero2sixT's Avatar
I figured you more of a Richard than a George...
