Engine cut out after turbo kit install
How much boost are you running? Run a NGK BR6EF or BR7EF depending on your boost level. 10psi or less I would gap at .032, over 10psi I would gap at .028-.030 IMO
ok i fibbed the gauge does hit 10, and at a quick wot throttle it pegs 10.0 and then cutts out/misfires, while the the gauges goes back around 11.3 and stays there till about 4000 in neutral, i put one new bosch 02 sensor in , new ngk tr6's gapped to .30 and it is a tad bit better but just barely, i took it down the drive way, at a 20 mph roll matted it and it never cleared, it would of kept cutting out/ misfiring until i let off, it just reeks of gas at wot, i also sprayed my vacuum lines on the truck with starting fluid while idleing thinking maybe a leak, but it never reacted, im just gonna drink on it anymore help would still be appriciated, thanks for all the input so far
