E-fans conversion on 03?
Old Oct 23, 2011 | 12:41 PM
05crew's Avatar
Default E-fans conversion on 03?
can any one tell me what is need for a e-fan vonversion, needing it to make room for my turbo setup. any info would be helpful...
Old Oct 23, 2011 | 12:43 PM
supersub's Avatar
stock e fans and a blackbear harness and a tune adjustment = done! thats what i run no problems!!!
Old Oct 23, 2011 | 01:57 PM
1989k1500's Avatar
Fans, a harness and tune. Or fans, a radiator, a harness, and a tune if you want 05 fans.
He will also need to get the bigger radiator if he wants to run the stock truck fans.
Old Oct 24, 2011 | 09:33 AM
Alpinestar's Avatar
Some other options: e-fans off an ls1 Camaro or Trick performance has an e-fan setup that drops right into the factory location and bolts up with the existing hardware. Trick's kit is more expensive but is definitely a cleaner looking install because the ls1 fans aren't a perfect fit. Trick also has different performance levels of fans that you can choose from. I went with the 1274 cfm fans because I was planning on trying to cram a bigger transmission cooler and an intercooler in front of the radiator.
Trick's fans before I installed them
Old Oct 24, 2011 | 09:38 AM
toddhowudoing's Avatar
Default e-fans
check out ff dynamics good prices, quality product
Old Oct 24, 2011 | 09:56 AM
Beau@SDPC's Avatar
Trucks Sponsor
You have plenty of options. You can swap to the OEM 34" Radiator & Fans from 05+ trucks. If you want to keep your 28" radiator, use the Flex-a-Lite 292, Trick Performance fans, or OEM LS1 or LT1 Fans.
Nelson makes a harness to work with all of these, and then they will just need to be activated in the tune.
Silver8ado
Sep 30, 2015 11:42 AM
old motorhead
Sep 29, 2015 08:22 PM
lycominghunter
26
Sep 25, 2015 07:50 AM
spooneralmighty
Sep 11, 2015 02:28 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
