dual walbros on a returnLESS system?
I'm just going my own route. You saw Joe's setup on TBSSowners, he helped me out with my setup and goals as well.
But I decided on going with a dual walbro instead of a sumped Magnafuel 4301 which was the original plan.
Yeah, he has only done about 10-15 TrailBlazer SS's and $750 plus 10 days of downtime is too $ for me at this point.
Performance Trucks Sponsor
We've done a handful of dual pump conversions.
Twin pumps, gut the bucket, install an Aeromotive firewall mounted regulator, stock feed line, use the evap as the return.
Works great! Held pressure solid up to 16psi, haven't gone higher than that.
Supports 650rwhp so far, plenty for 90% of the truck out there.
I don't see enough room in the bucket to run two pumps and the regulator, plus you'd want to regulate the fuel at the rails, not the bucket.
good luck,
good luck,
I will be doing my dual walbro 255, dual KB BAP with a corvette regulator this weekend. I will get parts list and pics. I have already done this set up on a truck making 750-800ish AWD
If anyone was curious, I took out my Aeromotive regulator on the frame rail. I reinstalled the Magnuson regulator built into the manifold mounted to the fuel rail. Moving the regulator fixed my problem. I now can hold 60 PSI up to 6300 RPM's without a problem. I figured the problem was due to restrictive fuel lines. The regulator on the frame must have been seeing 58 PSI, but the frame rail was only seeing 40 PSI. This surprised me since GM runs the regulator inside of the fuel tank (as far away from the fuel rail as you possibly can be). I would suggest everyone to run the regulator(s) as close to the fuel rails as possible from now on.
