Does your turbo spin at idle?
Where did you get the turbo from? Could be some roasted oil in there causing some drag.
This is the turbo that i bought
https://www.performancetrucks.net/fo...d.php?t=457927
I'm gonna play around with it some more tomorrow. After i gave it a little bit of gas it seemed to be spinning pretty good and didnt stop so maybe it was just seized up from sitting.
I responded to your PM, but I also just had this thought... These are floating journal bearing turbos which means the shaft spins in the bushing and the bushing spins in the housing. The bushing probably just hasn't centered up yet and has a bit of drag. Like I said in the PM, as long as the wheels aren't hitting the housing, go ahead and run it and see if it makes boost. If it does, then your
