Does a cold air intake box hurt or help a turbo system?
Old Jul 25, 2011 | 05:06 PM
black04's Avatar
Default Does a cold air intake box hurt or help a turbo system?
I've been running a short k&n on my turbo for awhile and recently someone told me that if i put an elbow with a bigger filter I would gain close to 40hp. I have an old Outlaw cold air intake box laying around that i could put in. So i was wondering if it would be better to make the cold air intake box work or if should just use an open element filter? I know there was some debate about what works better NA (cold air intake box or open element filters) but I'm curious whats better for turbo?
Old Jul 25, 2011 | 05:17 PM
smokeshow's Avatar
Mod with training wheels
Where's the smilie for blowing smoke up your *** when you need it...
No, you will not gain 40hp. Unless your turbo is currently drawing its air through a valve cover-sized breather. I doubt you'd see any difference between the two, as long as they are clean filters.
Old Jul 25, 2011 | 05:25 PM
black04's Avatar
It was on a local forum. According to him when he was tuning the car on the dyno he removed the air filter and the dyno graph jumped 40hp. He switched to a big filter with an elbow and said there was no difference between the filter on and no filter after that.
Old Jul 25, 2011 | 05:31 PM
smokeshow's Avatar
Something doesn't seem right lol. Either the air filter was way too small or dirty as hell.
Old Jul 25, 2011 | 05:35 PM
black04's Avatar
The way i have mine right now is just on the end of the turbo. Its about 4" long and pulls air from right behind the rad/fans.
Old Jul 25, 2011 | 06:09 PM
idahoblkss's Avatar
40 hp .... LMAO!!! does that bigger filter flow nitrous out of it ?
Old Jul 25, 2011 | 07:33 PM
black04's Avatar
Yeah i figured it might be more like 5hp or so. 40 hp is A LOT for such a small change.
Old Jul 25, 2011 | 07:50 PM
JankesGTO's Avatar
Dono I had a stock air box and swapped it out for a k/n directly on the turbo and butt dyno said it picked up...
Old Jul 25, 2011 | 08:51 PM
2toneblown's Avatar
I don't think it's the filter that's the problem. I think it is more so that with only a filter on the turbo, it can only get hot air from sitting right on top of the manifold and motor/head that is a million degrees. If you put a 90 on it and try and draw some fresh air from somewhere would be more ideal.
Old Jul 25, 2011 | 09:04 PM
TrickTurbo's Avatar
Truck Sponsor
Just moving the filter from the front of the turbo, to the side corner with a 90' turn you will drop your inlet air temps by 20+ degrees. Right in front you are pulling in hot air straight from your radiator.
The filter on the turbo works to a point, but if you are trying to get all you can then moving it will help.
