divided turbine housing
Old Jul 21, 2012 | 06:03 PM
KDavis04ss's Avatar
Default divided turbine housing
Would there be any problems running a divided housing on an undivided manifold?
Old Jul 21, 2012 | 06:08 PM
black00chev's Avatar
Slowest turbo build ever!
Shouldn't be any problem at all. Im sure most people aren't running a divided manifold with a divided housing.
Old Jul 21, 2012 | 06:32 PM
ForcedTQ's Avatar
Thumbs up
Good way to do things IMO. Allows you to install a "quick spool" valve to bring boost on sooner.
Old Jul 21, 2012 | 06:43 PM
Im running a divided housing with no problems at all
Old Jul 21, 2012 | 06:56 PM
Wilde Racing's Avatar
How do I change this text
it's not an issue, but it would be better to run a divided housing and manifold....
Old Jul 21, 2012 | 07:33 PM
KDavis04ss's Avatar
Thanks for the replies. I figured it would be optimal to match them up but the turbo that I would like to upgrade to later is undivided. So I would like to go ahead and build the hotpipes with an undivided flange.
Old Jul 21, 2012 | 07:51 PM
What type of headers are you going to build?
Old Jul 21, 2012 | 08:31 PM
KDavis04ss's Avatar
Im not building the headers just the crossover. First I was just going to to this. But I think with two passenger side manifolds, I will be able to turn the driver side down and forward. Run the crossover down by the balancer. I think it will look a lot cleaner. I would like to run the OBX headers but think they will come too far forward.
Old Jul 21, 2012 | 08:43 PM
I still say split the banks left and right and run a divided housing manifold......
Old Jul 21, 2012 | 09:10 PM
KDavis04ss's Avatar
What size pipe would you run then. 2.5 then neck down right at the flange? splitting the banks will make me run two wastegates right?
