Excellent! Thought I saw that elsewhere just couldn't confirm a part number.
I have really useless parts guys at some of the dealerships around here but I'll see what I can come up with. If anyone happens to have the zr1 part number that would be eve better! Thanks again! |
Sensor 12592525
Pig tail (in case others need it) 88988583 |
Just ordered one
Thanks for the help! |
Originally Posted by boostedsl2
(Post 5244995)
Sensor 12592525
Pig tail (in case others need it) 88988583 Digging up an old thread.... Does the Gen IV harness (truck) have the correct MAP sensor pigtail to use the ZR1 MAP or do I need to buy the ZR1/different pigtail to make it work on the truck intake manifold? Thanks!! |
Yes the harness works with zr1 map. It’s what I use |
What are all of you considering a Gen 3 vs Gen 4? seeing lots of wrong info here, some of its in old posts though. |
2012+ is a direct plug in and go.
Pre-2012 needs a two pins swapped. |
Originally Posted by FFDP
(Post 5458076)
(Post 5458076)
(Post 5458077)
correct. And A P59 ecm can run 3bar. Mine is. I haven't ordered my harness yet, so I guess I will see. Which color wires need to be in what order? I was planning on running a E38 ecm I already have. Any issues with that? Thanks. |
(Post 5458076)
